problem with ext. sd since kitkat update
Postby cmario » 06 Apr 2014, 10:27
since the update to kitkat reading/writing from/to ext. sd doesnt work.
Sometimes the r/w attempts even lead to app crash.
Due to some infos the reason is a change of the permissioning concept/functionality which was not or bad communicated by google.
Is the issue already known ?
Thanks for your attention.
cmario
Re: problem with ext. sd since kitkat update
Postby kitercuda » 19 Apr 2014, 12:10
Android in version 4.4 reduced access rights to SD card.
Use application SDFix. This will solve your problem. Unfortunately you must root your device before applying SDFix
https://play.google.com/store/apps/details?id=nextapp.sdfix
