north up?
north up?
Postby starborough » 27 Mar 2014, 16:17
Hello
I do like tge application, but the orientation of the map doesn't seem right.
Normally I would hold a map either track up or North up. After the gps
Has settled I find that this map settles with north at about 45 degrees
And my first track to the North of my house also settles in that direction. .
Is therea way of setting this?
starborough
Re: north up?
Postby kitercuda » 27 Mar 2014, 19:49
Long tap north symbol...
If map is in "finger move mode" short tap North symbol.
(Easiest set moving map by finger - tap and drag map by 2 fingers)
