Yandex maps position error
Postby Stranger » 10 Nov 2013, 17:25
Dear Petr,
First of all, thanks for your wonderful app!
I use offline yandex maps with the app. Every time I use them I get a latitudinal position error of about 20-30 km. I normally use SAS.Planet to export maps into the sqlite database, but I have also tried RMaps and an older version of MobAC (the current one doesn't support yandex maps, as well as many other map sources) with the same result.
After doing some research I found a discussion of a similar problem here. As it turns out, yandex maps use a slightly different map projection (Mercator ellipsoid) which accounts for the error.
Some apps (like the Locus by the above link) can handle this peculiarity. Could you somehow fix it too, please?
Oh, did I forget to thank you for the amazing app? :)
Stranger
Re: Yandex maps position error
Postby Onuff » 10 Nov 2013, 18:07
I too faced such mistake but didn't pay strong attention. let's know
Postby kitercuda » 11 Nov 2013, 13:01
This winter will be vector map available.
Postby Onuff » 11 Nov 2013, 13:34
Ok.hold
Postby Stranger » 12 Nov 2013, 06:38
kitercuda wrote:This winter will be vector map available.
That's great news!
However, I am not aware of any vector maps of Russia suitable for VFR. Could you give us some hints about which map formats FiF will handle? Have to be prepared, you know :)
BTW, RMaps can also do Mercator on ellipsoid.
Stranger
Postby kitercuda » 13 Nov 2013, 10:01
I will try to use in the begin vector OSM - it is free.
Look here:
http://download.geofabrik.de/openstreetmap/
Postby Onuff » 13 Nov 2013, 18:47
and it is possible to add then the cards the user cards as rmap
Skyvector
Sovetskey topographic map))))
