possible issue on version 12.31 and 12.32
Postby asxavier » 31 Aug 2013, 01:57
Hi, I've installed the last version from Google Play and downloaded the last version of the World nav database for my home country, Brazil.
the next day I was on a flight and I just couldn't add waypoints to a route from the search page.
I can open the add waypoint page (+WPT) and I can search or browse the database, but when I select the waypoint that I want to add to my route, I get back to the Edit route page and I see a "unable to open database" alert.
if I use the Map edit button everything works fine.
my databases are on my SD card and I have a Samsung Galaxy Tab 7 Plus, rooted. it has worked perfectly until now.
does anybody else have this same problem, or is it just me?
maybe it's a bug?
I'm not being able to export from my World database as I was before, but I'm getting a message that it's no longer possible ("Export from the World database is not allowed").
thanks,
Xavier
P.S.: version 12.32 shows the same issue.
asxavier
Re: possible issue on version 12.31 and 12.32
Postby asxavier » 02 Sep 2013, 22:50
I've just installed the latest version I used that worked without problems, that is 12.30, and it worked flawlessly!!
please take a look at this issue, since I really like this app and I would like to use the latest version.
is there any information I can provide to help look for the problem?
thank you and best regards.
asxavier
Postby kitercuda » 03 Sep 2013, 11:08
I checked it out. On my device it is working without problems. I can add WPT via +WPT button to the route... Do you have still this problem?
Exporting from wordl database was denied mayby 2 month ago... Possible exporting only user defined WPTs.
Postby asxavier » 03 Sep 2013, 22:48
yes, it only worked with version 12.30.
something changed on the database structure?
I was supposed to clear my routes and start over for it to work?
there's some log that I can generate and send you to check?
asxavier
Postby kitercuda » 04 Sep 2013, 17:37
I did not make any changes in database structure. I do not know why you have this problems. Let me think...
Postby asxavier » 04 Sep 2013, 22:32
I just removed the app and then reinstalled it.
it's working perfectly now!
I probably messed up with my database somehow. it's fine now.
I just lost my activation. I'll send you an email about it, ok?
thank you and sorry for the time spent with it.
regards
asxavier
