Vytvoření route
Vytvoření route
Postby rstork » 16 Aug 2013, 18:00
Dobrý den,
dnes jsem zakoupil aplikaci a začal v ni plánovat trasu pro zítřejší let. Bohužel po vložení 3-4 WPT aplikace vždycky spadne. Nějaký návrh co s tím? Takto je bohužel nepoužitelne. Zařízení Samsung Galaxy Notebook 8.0, GT-N5100.
Mějte se fajn,
RST
rstork
Re: Vytvoření route
Postby Onuff » 16 Aug 2013, 18:03
Do you speak English
Re: Vytvoření route
Postby rstork » 16 Aug 2013, 19:12
Seems I have found the reason of application failures during waypoint insertion into the route. If I single-tap on selected airport the waypoint is inserted as expected. If I double-tap (as I am used to) the application usually crashes.
rstork
Re: Vytvoření route
Postby kitercuda » 18 Aug 2013, 05:36
I tried it, but no crasch.
Please can you described more, how to make crash? Which list was opened etc.
Re: Vytvoření route
Postby rstork » 24 Aug 2013, 11:06
I have recorded video with steps leading to crashes. Althought it is pure quality I belive it helps. You can see on http://youtu.be/Uxh-8N1PU_4
rstork
Re: Vytvoření route
Postby kitercuda » 24 Aug 2013, 15:26
Thanks, I will have a look...
Edit:
I tried it, but no crash...
Re: Vytvoření route
Postby ludastorm » 16 Sep 2013, 18:41
I have also problem to create a route after 2 last updates. I can add only one point, when I want to add the second waypoint it says "cannot open the database". I have LG Optimus One Adroid 2.3.
ludastorm
Re: Vytvoření route
Postby kitercuda » 17 Sep 2013, 04:43
Strange, there were no changes and at my Samsung Galaxy S4 it is working.
I made some changes. I hope next upgrade will solve this problem...
Edit: I just have uploaded version 12.42 - Please try and write here is problem was solved.
