Route creation
Route creation
Postby droopstop » 24 Jan 2013, 21:23
I have created several routes and when I activate they all of them have the same fault. If I create a route of waypoints1,2,3,4 and 5 when I activate the route it always misses waypoint 1 and goes straight to waypoint 2. Any suggestions please mate, thank you
droopstop
Re: Route creation
Postby kitercuda » 25 Jan 2013, 13:50
WPT-1 is start waypoint. So when you activate route, it is supposed you are at WPT-1.
WPT-1 is needed for calculating whole route length etc. In the near future it will be used for fuel calculation.
Re: Route creation
Postby vooger » 29 Jan 2013, 21:21
Hi!, how about visual route creation? It will be good that each WP will have "add to route" in menu by long tap. With respect...
vooger
Re: Route creation
Postby kitercuda » 30 Jan 2013, 07:02
Hi, I just uploaded upgrade, with "upgrading" long tap at the map. Yuo can select from:
- Nearest to tap position
- Nearest Airport VHFs
- Nearest METARs
- Create new WPT
Visual route creating will follow.
Re: Route creation
Postby vooger » 02 Mar 2013, 11:59
Still waiting for visual creating and adding the screen with route plan.
vooger
Re: Route creation
Postby vooger » 02 Mar 2013, 12:09
And one more, at present, when you have an activated route and open it for having ETA of some following point you will see the ETA in 12-hour format of UTC. It may lead to light confuse :!:
vooger
Re: Route creation
Postby kitercuda » 02 Mar 2013, 18:11
I will change it to 24h format, next upgrade...
Re: Route creation
Postby Onuff » 03 Mar 2013, 14:53
super!
very goooddddd!!
Re: Route creation
Postby marpdiaz » 31 May 2013, 01:33
Slighty different subject:
how do i use my user wpts in a route?
the .wpt file is in the GPS_ILS_VOR directory, but i dont know how I get them listed in the route creation interface.
thanks,
Re: Route creation
Postby kitercuda » 31 May 2013, 06:40
You must import wpt file first...
User guide chapter: 3.5 Importing nav items from external sources
