How to setup airport PDF information
Postby kitercuda » 09 Dec 2012, 17:59
From version 8.2 application support quick PDF access.
Example:
You are flying and you see airport LKZA at the map and you decide to lend here.
Long tap at LKZA (until device start vibrate). Then Nav item list will appear.
Long tap at LKZA (until device start vibrate). Then context menu will appear.
Tap menu item PDF and you can see this:
How to use it:
1. Be sure you have installed some application for viewing PDF files (for example Adobe Reader) at your device.
2. Every PDF files you have to upload to your device. Every airport can have a lot of PDFs (STAR, SID, ADC, etc.)
3. Location of PDF files depend of ICAO airport code. The easies way how create desired folder is long tap at the airpot (at Nav item list) and select PDF. Application will create folders for pdf files of this airport.
4. Look at FLY is FUN data folder (default folder is GPS_ILS_VOR at your SD card). Inside is folder called PDF, inside of this folder is folder which depend of country (LK, K, LZ...) and inside of country folder is placed airport folder (LKZA):
GPS_ILS_VOR/PDF/LK/LKZA - here upload yout PDF files. Every airport has its own folder.
Re: How to setup airport PDF information
Postby olravet.fr » 10 Dec 2012, 22:02
OK !
(Just one thing... you decided to land here)
Post to be deleted just after!
olravet.fr
Users browsing this forum: Google [Bot] and 9 guests
