Postby Onuff » 19 Apr 2015, 13:57
:D ok
translate
Postby kitercuda » 20 Apr 2015, 05:59
OK.
You still do not use IL-76 aircraft symbol :-)?
Postby kitercuda » 21 Apr 2015, 11:20
Repaired: Инструменты only
Postby Onuff » 22 Apr 2015, 13:10
Very good.
Postby Onuff » 31 May 2015, 05:07
my friend flies by helicopter.
He asks as to keep a track, to transfer and open in routes?
Postby kitercuda » 04 Jun 2015, 12:48
The problem is, there are a lot of points in track. Minimum distance between WPTs in the route is 500m.
Your friend can display desired track at the map. Long tap at it and then click Show at the map centre.
Postby Onuff » 04 Jun 2015, 21:04
In total anything.
I did as you speak.
In the program androzic, the author made, somehow, that the route is laid and in big corners changes. :D
Postby Onuff » 02 Jul 2015, 22:01
List point have not names
Postby Onuff » 05 Aug 2015, 18:09
recently programs works slowly. especially at a route choice. long black screen. lag.
Postby Onuff » 26 Sep 2015, 18:32
Настройки
