Baro or GPS Altitude in exported tracks?
Re: Baro or GPS Altitude in exported tracks?
Postby kitercuda » 30 Oct 2013, 08:20
I found one snall bug - 12.60 solve it, but the bug has an impact only if GPS does not have altitude data.
Did you try it again?
Edit:
I found the problem. If the applicaton runs on the background, baro sensor is switched off and application use the last walue...
Next upgrade will solve it.
Thanks bitbrusher...
Postby bitbrusher » 03 Nov 2013, 16:38
Hi Petr
No need for thank. WE thank you for this piece of dedicated and great work.
About the bug: i was affraid it was a bug on my new Note II (the last one was stolen).
But one this I clearly remember from this flight: I read the altitudes correctly (comparing with acft altimeter) throughout the fligth (until landing).
Do you think FiF switched to GPS altitude to display correct altitudes and read from BARO to record track?
Very odd!
bitbrusher
bitbrusher
Postby kitercuda » 04 Nov 2013, 09:01
Hi, any observation of troubles with application and giving me report deserve thanks :-). This is only one way, how to do FiF better...
I do not think so, application switches to GPS altitude by itself. If altitude strip is blue, FiF uses baro alt for logbook too.
Running on the background is mean for example listing of Nav items too. I hope, version 12.62 solves the bug.
P.
Postby bitbrusher » 17 Nov 2013, 13:41
Hi Petr
I went to a flight yesterday. It seems this bug was zapped.
Thank you.
bitbrusher
bitbrusher
