New version to downalod
Microsoft Flight Simulator X to Android
Postby kitercuda » 25 Dec 2019, 09:38
Version 1.5
app-debug.apk
(281.57 KiB) Downloaded 6271 times
Re: New version to downalod
Postby flyyyer » 18 Apr 2020, 09:13
Somehow I missed this upgrade.... Many thanks Petr Will go flying with it later :)
Postby jnharmon » 09 Sep 2020, 02:11
Is there by chance an update to the Windows service app that goes along with this?
jnharmon
Postby turillo1986 » 17 Sep 2020, 15:04
Can we use this also flr the new flight simulator 2020? if not, do you plan to make a version for it?
anyone can explain me how to setup the pc for this to work? i know my pc ip and port, but how do i get the gps data out from the sim and on the wifi network?
turillo1986
Postby jenki29 » 27 Jan 2021, 19:19
For msfs2020 with FLY IS FUN is working this app: https://play.google.com/store/apps/details?id=com.aarongamble.simconnectandroidsync&gl=SK
I found it after hours.
Enjoy ;)
jenki29
Postby ichthys » 28 Feb 2021, 12:24
jenki29 wrote:Hi,
Enjoy ;)
Very cool you found my app! How did you find it? I hadn't posted it anywhere online, just the play store. I did just today finally put a post on reddit about it: https://www.reddit.com/r/MicrosoftFligh ... oid_flight
ichthys
Postby jenki29 » 12 Apr 2022, 14:26
It has been real research :lol:
jenki29
Postby flyyyer » 29 Oct 2022, 09:12
Hi Guys, Can someone remind me of the procedure of how to connect my tablet using FIF to both MSFS and Xplane 12 please as I've just upgraded to fandangloid PC. I have done it before on older programs but I've lost the plot on this now..... Thank you.
Regards Peter G
Postby flyyyer » 17 Dec 2022, 10:09
Hi All,
Can someone help please.
I have successfully connected FIF to MSFS using Simconnect. All works brilliant...... This navigation is better than the actual sim nav and it also replicates what I use in my airplane.
I cannot work out how to create a connection to Xplane. This can be for Xplane 11 for guidance but I will then be using XP12.
PLEASE Can someone post here how they do it.....someone must have done it................
Postby flyyyer » 23 Dec 2022, 16:01
I managed to find a solution that works. There maybe other solutions but this works for X-Plane 11 and 12. (Use Simconnect for MSFS) You will have to look for "X-plane to GPS" (Ver 1.62) on Google, ..... keep going till you find the (free) link. It is no longer on the Playstore site direct but you will end up downloading it from there indirectly after trawling through the rubbish links. If you install it on your Android device that is on the same network as you PC X-plane 11 then it will automatically find it and configure X-Plane 11. You can use these same settings to manually configure X-Plane 12.
You have to do all the "Mock locations" stuff for it to work but it works great.
It would be good to have FlyisFun listed in the X-Plane list of available Mapping software......for me it is the best worldwide supported airplane mapping software you can use, a shame for it not to be listed there........
All quiet on this forum I think but if anyone needs help shout up....
PJ
Return to FSX to Android
