Italy - strange airfield identifyer
Postby Michele bassetti » 04 Mar 2023, 09:05
Hello, since last navdb update, many airfield in Italy have wrong/double identifyer. Up tò 30 km zoom, the id are correct. Zooming out further, starting from 50 km many small airfield are filtered, those that remains change their identifier with a wrong one.
I give you an example:
Mazzè
correct identifyer should be:. LIFM - Il Falco
Current navdb identifier:. LIB2 - Prati Nuovi
Could you check It out? In planning Is quite annoying.
Thank you
Michele
Michele bassetti
Re: Italy - strange airfield identifyer
Postby kitercuda » 03 May 2023, 13:27
Thanks Michele,
FIF nav database uses a lot of sources. There are 2 airports at the same position. I will repair it next database upgrade.
Postby kitercuda » 17 May 2023, 14:12
Repaired...
Postby Michele bassetti » 29 Jan 2024, 10:55
Now identifiers looks Gold, thank you.
In North of Italy in the last aip we had some airspaces modification that are still not implemented in fyf nav db.
In particular in Limf area.
Could you also verify this?
Thank you
Michele bassetti
Postby Michele bassetti » 07 Mar 2024, 20:39
Hello, with 2402 now aispaces in Turin area looks up to date. Thankyou
Michele bassetti
Users browsing this forum: No registered users and 32 guests
