Checklist
Checklist
Postby vtiukin » 18 Dec 2015, 10:11
Hi! My suggestion is to add a checklist to a program. So you can create your personal checklist. I'm using this app for my checklist:
https://play.google.com/store/apps/deta ... .checklist
And it has a position, don't forget to switch ON Fly is Fun :D It whould be nice to have it in Fly is Fun!
Another suggestion, is there any possibility to use Fly is Fun as a GPS tracker, so your family or friends could see you on a map?! :roll:
Regards,
Slava
vtiukin
Re: Checklist
Postby kitercuda » 21 Dec 2015, 12:41
I will put check list on my ToDo list. The check list will be bing with the aircrafts at the aircraft list.
I am currently implementig the connecing FIF to external data sources.
GPS tracker is already implemented.
You need:
- GSM data connection.
- Fill an aircraft data and set any aircraft in use.
- Open logbook (long press LOG value window or Menu / Tools and info / Logbook)
- Press the aircraft button
- Menu / New
- Fill the aircraft
- Long press at the aicraft and then Set in use.
- Enable broadcasting/receiving
- Long press ACC value window, the flashing dot must be green or Menu / App settings / Preferences - Virtual radar
Re: Checklist
Postby Mano » 18 Nov 2019, 20:00
otvorim tuto temu, vsimol som si ze pri vytvarani lietadla si mozem napisat checklist... da sa to nasledne niekde aj odskrtavat ? ci to je len tam napisane... dakujem
Mano
Re: Checklist
Postby kitercuda » 20 Nov 2019, 18:12
Check list:
Edit some aircraft (Menu / Information Aircrafts) and press Check list button.
Unfortunatelly it is text only. I will think how to display it easy during on board prepraration for the flight.
