Stratux
Stratux
Postby Mikedyos » 16 May 2019, 09:19
Will you also be adding the Attitude Indicator to FIF to work with the AHRS on Stratux?
Thanks,
Mike
Mikedyos
Re: Stratux
Postby Tonio » 16 May 2019, 14:20
Hello Mike
Yes, since version 22.10 it is possible to connect Fly is Fun with the Stratux
- Airplane broadcasting ADSB out signal detected with the Stratux are displayed on the Moving map and on the elevation/terrain map
- Stratux AHRS module is used to and display in the compas of the 2 instrument screen as well as on the elevation/terrain map
photo_2019-05-16 15.09.42.jpeg (141.63 KiB) Viewed 14440 times
Have Fun
Re: Stratux
Postby Mikedyos » 16 May 2019, 15:07
hi,
My question was regarding the pitch indicator.
Mike
Mikedyos
Re: Stratux
Postby Mikedyos » 19 May 2019, 09:34
found it!
I have since purchased a Stratux. it appears to be very good. not flight tested it yet.
Mikedyos
Re: Stratux
Postby kitercuda » 20 May 2019, 19:21
Anyway:
- The artificial horizont is displayed only when Stratux has GPS fix.
- You can calibrate AHRS by long pressing the slip indicator at the bottom of the screen.
Re: Stratux
Postby Tonio » 09 Jun 2019, 10:21
An updated version of the User Guide (English and French yet) is online.
You can find it there http://funair.cz/forum/viewtopic.php?f=11&t=5994
or download it directly from FIF
The new chapter 18 of the updated, describe how to setup and use the Stratux
So simple
You can also down directly the guide using this links
English version http://www.funair.cz/downloads/manuals/flyisfun.pdf
French version http://www.funair.cz/downloads/manuals/flyisfun_fr.pdf
Have fun
