Metar around map pointer, regardless gps
Postby Holton181 » 18 Aug 2017, 21:02
I don't know if this has been suggested before, but here we go:
When planning or preparing a flight before gps fix, it would be nice to be able to download metar/taf from nearby the map pointer instead of my gps location.
Also, it would be great if we had an option to get the metar/taf for any airport either by clicking on it on the map (menu item) or from the nav database menu's. With and without gps fix.
Of course setting the QNH from this metar as usual.
Best Regards
/H
Holton181
Re: Metar around map pointer, regardless gps
Postby Tonio » 19 Aug 2017, 11:36
Hi Holton,
I believe all features you are requesting/suggesting are available …
1 - METARs and TAFs for a point
-> Long tap on any point of the map
-> select “Nearest”
Then
-> select “METARs and TAFs” around
and you get them
2 – METARs and TAFs for planned route
Open “Routes” library
-> Long tap on “planned route name”
and you get them
if you have no Internet connection you get “METAR download error” message but you can display previous displayed data
3 – Adjusting QNH
Once you get METARs info for a point
-> Long tap on displayed QNH value
-> select “Adjust QNH”
Postby Holton181 » 19 Aug 2017, 19:21
Ha ha! Indeed I'm feeling stupid right now, Tonio :oops:
I should have known, been playing with the long-tap menu many times, must have forgotten :roll:
The planed route was new to me though. Thanks!
Holton181
