No restart of FiF after leaving preferences
Postby Holton181 » 13 Dec 2016, 12:03
It would be nice if FiF did not restart every time a change to the preferences has ben made, or even after only enter the preferences to verify something. I can understand that some settings might necessitate a restart to take effect, but hardly everything. And if a restart is necessary after a certain change it would be nice to get a warning and the possibility to postpone the restart (and changes to take effect) to whenever the user do it manually.
This because I like to be able to do changes (or verification) while in the air, navigating and recording track, without getting everything to be interrupted by a restart.
As an example I would like to be able to recalibrate the barometer while flying. I will post a separate topic about this request for details and motivation. Edit: Found here
BR
/H
Holton181
Re: No restart of FiF after leaving preferences
Postby kitercuda » 14 Dec 2016, 23:26
Restarting is needed, but I want to change calibrating - it will be available ousdie of preferences.
I want also implement calibration at different speed - because usually if ground speed is 150 knots, cabin pressure is several mbar less. Iw will be possible to se for each aircraft..
