Skyvector HI,LO,VFR (maps)
Re: Skyvector LO Россия
Postby chid » 07 Dec 2013, 19:24
Im trying to get the VFR and Lo maps for Europe (mainly Greece), Ive downloaded SAS Planet and followed the procedure including changing the date etc in the params file but it appears Sky vector have changed something stopping SAS Planet accessing the tiles, do you know anyway to solve this, or do you have the maps saved somewhere I could download them from?
chid
Postby bitbrusher » 08 Dec 2013, 11:54
Hi chid
I just checked and mine and it is working as expected.
What version are you using?
Did you edit the THREE "SkyVectorWorldXXX.zmp/params.txt" files?
where XXX=VFR Hi Lo
The "DefURLBase=" line should look like this for this month in the three files:
DefURLBase=http://t1.skyvector.net/tiles/302/1312/
host t1.skyvector.net is resolving and is reacheable ?
$ host t1.skyvector.net
t1.skyvector.net has address 64.34.195.170
$ ping -c 1 t1.skyvector.net
PING t1.skyvector.net (64.34.195.170) 56(84) bytes of data.
64 bytes from skyvector.com (64.34.195.170): icmp_seq=1 ttl=53 time=732 ms
--- t1.skyvector.net ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
(be aware they have a couple of servers. the IP you get will probably be different)
cheers
bitbrusher
bitbrusher
Postby Verun » 09 Dec 2013, 19:00
Hi all,
i've quite strange problem.
Opening SAS and putting in the sas.maps folder the folder SkyVectorWorldVFR.zmp with Params file modified, i get the LO map instead of the VFR one.
Any ideas?
Verun
Verun
Postby bitbrusher » 09 Dec 2013, 20:35
Verun
DefURLBase should read:
Code: Select all
DefURLBase=http://t1.skyvector.net/tiles/301/1312/
instead of .../302/...
directory .../302/... is for World Lo tiles
and .../304/... is for World Hi tiles
cheers
bitbrusher
bitbrusher
Postby Verun » 09 Dec 2013, 21:59
thanks for your help bitbrusher.
Verun
Re: Skyvector LO VFR Россия and other countries
Postby Onuff » 11 Dec 2013, 18:55
Postby Onuff » 08 Jan 2014, 13:29
World map Google map
http://yadi.sk/d/JQgx2Gt1FeWQ5
Re: Skyvector HI,LO,VFR (maps)
Postby Onuff » 19 Mar 2014, 19:20
Postby pospel » 25 Mar 2014, 03:09
pospel
Postby Onuff » 25 Mar 2014, 18:47
