Postby kitercuda » 30 Oct 2013, 08:23
I am thinking about possibility of moving compass rose up (user option) and display altitude and speed strips...
Postby Onuff » 30 Oct 2013, 20:46
ok)))
this is idea)))
Postby mi8t » 31 Oct 2013, 07:20
Please do logbook in summing up the month and year.
Where to get a database of artificial obstacles ?
mi8t
Postby kitercuda » 31 Oct 2013, 12:25
Open logbook. The easiest way is customize screen fitst and select LOG - Logbook elapsed time. Then log tap this value at the main screen..
There are buttons From and To at he logbook page. Press the and select date. Then press Menu/Summary and you will get what you want...
Postby Onuff » 02 Dec 2013, 20:28
Peter you added the DTA function
as to improve it
so that DME to any point of a route
Postby kitercuda » 03 Dec 2013, 08:26
You can see DME to any point of route - when open Route dialog
There are two quick access to route dialog:
- Tab aircraft symbol at the centre of the route
- This feature will be available from Version 13.20: Tap: End of route ETA, Distance to the end of route, End of route ETE
Version 13.20 will be available no later then tomorrow. We are finishing VFR airport patterns for Germany.
Postby Onuff » 03 Dec 2013, 19:32
No
1-I have DTA and DME to the set point
2-and ?. in the future it will be possible to start the program at a window without the emulator?
Postby kitercuda » 04 Dec 2013, 07:16
DTA is possible to set to any route WPT. When editting the route. Edit route and swipe route point from left to the right. Then you will be able to edit DTA.
Postby Onuff » 05 Dec 2013, 12:19
it is difficult to understand I will try. and on 2?
Postby kitercuda » 05 Dec 2013, 20:31
What you mean Start program at window without emulator?
Users browsing this forum: No registered users and 15 guests
