Calculation of Max Elevation of ground for route planing
Postby sonntagc » 02 Oct 2016, 12:38
you made a perfect tool, thanks
for the flight planing the MAX elevation figuers / or max Ground elevation is important.
You have a tool that is checking the information based on a list / or gps data.
It could be very helpful if I could choose there the segments of the route planing , to get the informations for eache segment....
The best this information could be directly integrated in the route overview.
Christian
sonntagc
Re: Calculation of Max Elevation of ground for route planing
Postby Viking » 03 Oct 2016, 19:41
I'm not sure to understand your question, but if you want to know the max elevation for each leg of a route:
You edit the route, a long tap on a waypoint (the second, third, etc..), then "Edit WPT", and after on "Calculate" key.(be sure to check "Use terrain data" and "Use obstacles" they must be downloaded before)) and confirm with the green key (bottom and right).
FIF gives you max values (AMSL) for terrain and obstacles for this leg. You repeat for each leg and after, you can select a high for each segment.
Sorry for my poor english.
Jean-Pierre, LFFD.
Postby kitercuda » 06 Oct 2016, 15:00
Hi, I will do it on one click. I must do import some map format and then I will do it.
Postby sonntagc » 05 Nov 2016, 22:17
Hi. Viking
Thanks for the info. It works.
And al solution, that the result would be integrate, as the distance and the curse in the route overview, with all legs..
Thanks a lot...
The tool is really fantastic.
sonntagc
Postby sonntagc » 07 Feb 2017, 23:58
Thanks a lot. With your last update you did integrate the elevation of the flight segment in the route planing overview
And you did it in a very smart way.
It's really amazing how many improvements you made on this "never would like to fly without" tool
Five stars are not enough....
Thanks a lot
Christian
sonntagc
Postby docmeier » 11 Feb 2017, 17:44
Hello Petr,
very nice software!! I guess you hear that often. The max elev calculation is another highlight.... but... not a big “but“, however the results of the calculation are not displayed entirely, only the first digits (screenshot attached).
Your software is top!
Most sincerely,
Docmeier
docmeier
Postby kitercuda » 13 Feb 2017, 21:01
Version 19.50 solves it.
Postby sonntagc » 27 Feb 2017, 22:38
Dear Petr
The route overview with all the segment, with details, and max elevation. Distance, course..... Wind and all of this is perfect.
If I could export this in a way that I can print it out, just as a text in the format like it is in you segment view. Would be great, I like your tool, but I never trust my phone accu, so I prefer to have the flight informations in printed form too.
Best regadrs
Christian
sonntagc
