Wish list ?
Wish list ?
Postby pjp » 13 Mar 2014, 06:33
only a few points:
- improve glider options, similar for XCSoar (xcsoar.org) for example (profile, MacCready, some calculation, ..)
- possible to define "home" airport.
- increas RWY infos in box for airfield, actually there size of one RWY and not direction, please, put there all size of RWY + directions.
- please, pre-defined an aircraft types.
- somehow sync between more mobile / tablets (no less as preferences + logbook).
- simply switch inside an list of pre-defined some WPT ...
Something more next time ...
And one bug - Summary in logbook for all aicraft, wrong calculation of hours for SE.
Pavel
pjp
Re: Wish list ?
Postby kitercuda » 13 Mar 2014, 10:14
Hi:
I am thinking about it long time... I hope this year
OK
All infos will be refactored soon.
Where to find a list?
At this time, you can export preferences and import - via file
You can create a folder and copy WPTs there
I will have a look
Re: Wish list ?
Postby pjp » 13 Mar 2014, 16:06
:-) http://en.wikipedia.org/wiki/List_of_aircraft - but this list is absolutely crazy, for CZ reality will be good L 13SW/SE, Z 26/40 family + C150/172 family (for EU too). Probably L 40, L 200 + a few more. Unfortunately ULL scene is much more complicated ...
But - maybe will be better to collect this infos from users of this sw by some good form ...
I mean use existing WPT - airfield, etc from public sources, not only an private WPT. Maybe will be better call this as "favourite WPT".
Yes, I can (and logbook ?), but I can use https://play.google.com/store/apps/details?id=com.bittorrent.sync and define some folder for sync, maybe GPS_ILS_VOR folder ?
And one think for glider - motor glider, in CZ we mostly know only L 13SW/SE, but this "glider" nobody use for fly without engine (I never heart about no one), but in around world exist much more improved version of this category aircraft, probably if you improve an functionality for gliders in your sw, will be good to define there an special category for this aircraft (engine + glide profile).
Logbook - I forgot, maybe will be good some possibility for some import from an csv or xml file. CZ aeroclub use an sw as logbook for people and aircraft, name I don't remember and I don't know this sw and his possibility.
Pavel
pjp
Re: Wish list ?
Postby kitercuda » 14 Mar 2014, 07:00
- You can import from external sources - KML, GPX.
- If you want to copy all from one device to another (or copy from internal memory to extrnal SD card) - copy GPS_ILS_VOR folder. Inside this folder is folder Database. There are two files:
gpsilsvor.db - all WPTs, Routes
logbook.db - logbook (include aircrafts, pilots, logbook)
Re: Wish list ?
Postby pjp » 14 Mar 2014, 10:19
I checked, but if I fill logbook and synchronize this folder from one device (Samsung S3) to second (Asus ME173), logbook in Asus still empty ...
I really don't know why ...
Pavel
pjp
Re: Wish list ?
Postby kitercuda » 15 Mar 2014, 06:52
Open Nav item list, press Menu/Import...
Do not use MTP for copying files. There is a bug (Android x windows). Always mount your storage like "External stroage" when connecting to PC.
Re: Wish list ?
Postby pjp » 15 Mar 2014, 16:37
I know how I can make import gpx & kml, but I don't understand relation between this import and logbook (?) ...
BitTorrent® Sync use they own protocol and can make sync direct between different devices (mobiles or tablets) without PC, there are, I'm afraid, no mistake.
I use this sw for sync files of Locus Pro and absolutely no problem.
Pavel
pjp
Re: Wish list ?
Postby kitercuda » 17 Mar 2014, 07:04
Logbook has no import yet. You must copy logbook.db.
Re: Wish list ?
Postby pjp » 17 Mar 2014, 08:42
Yes, but this didn't work, really ...
And - I checked export/import preferences and this functionality are little bit crazy (again Samsung S3 source, Asus ME173 target):
- export into sw folder, but import form one folder up to sw folder ...
- some aircraft & pilot define in both, in import in target all lost but didn't import new.
- preferences - I didn't check.
Sorry, but there are something really wrong.
And for sync I put all files into one zip file to avoid any problems with transfer between devices.
And one more thing - I check import gpx & kml files from www.airquest.cz, but gpx files work fine, but in case kml file sw didn't import absolutely nothing ...
Pavel
pjp
Re: Wish list ?
Postby pjp » 17 Mar 2014, 17:47
Please - remove from import preferences import of sw folder, unfortunately different devices have got different way to external storage SD ...
And - please, create definition of this folder more user friendly ...
Pavel
pjp
