SID STAR RNAV WPTs
SID STAR RNAV WPTs
Postby marpdiaz » 29 May 2013, 16:48
Is there any way to include the IFR fixes associated with instrument departures, arrivals and RNAV approaches for the brazilian airspace?? this would be very helpful because we are usually directed to those wpts.
let me know if i can help. This will complete all my needs on the software.
Re: SID STAR RNAV WPTs
Postby kitercuda » 30 May 2013, 06:54
I will add IFR AWY and holding patterns in a short time...
Postby marpdiaz » 30 May 2013, 16:28
The AWYs may be useful but they are restricted to FL150 and above in all brazilian airspace. So most GA traffic dont use them.
For us the most important missing data are the wpts in IFR departures,arrivals and GPS approaches (we call the last RNAVs procedures).
They could be found in PDF format at
http://www.aisweb.aer.mil.br/?i=cartas
once there, click on the blue link below AIRAC: "Paginas Inicias (Checklist PDF)"
there is a pdf with a list starting around page 61 (section "COORDS")
There is a catch, however, runway threshold fixes dont have unique names.
for instance all RWY 18 runway thresholds are named RWY18 in this list. One may
prepend the airport indicative to differentiate them. The list is heterogeneous regarding
the coordinate format (ddd mm.mm as well as ddd mm ss.s).
by the way, i made a couple of flights using the srtm terrain files and found the system excellent, plenty of info with a friendly interface.
Postby kitercuda » 01 Jun 2013, 14:13
I have checked Brasilian terminal WPT and it is OK.
- When importing check IFR WPTs
- When using application (map screen) long tap at compass rose for customizing screen
- Check blue Not specified - it is possible at zoom level from 0.25nm till 6nm
Postby marpdiaz » 02 Jun 2013, 14:46
Ok I found them
many thanks,
