Version 12.40
PostPosted: 08 Sep 2013, 19:46
- Holding patterns (now IFR only) Import the world nav database again. You must check all checkboxes like Navaids, IFR TWPTs, WPTs, Holding patterns. If you do not see them, roll. Then look at the nav item list...
- Route summary (Open routes list, long tap at the route and then select Summary). Distance, Estimated flight duration, Fuel consumption - depends of the wind!
- Sort Logbook ascent, descent. Open the Logbook, press Menu, Sort...
- Quick open Logbook - long tap LOG value on the main screen. If not visible, customize screen (Long tap compass rose)
- Removed bug - NDB with frq for example 1145 was displayed 114.5 (For fixing import the world nav database again)
