How to create my own markers?
Postby bitbrusher » 01 May 2017, 02:53
As the subject says, how to create and import my own outer and middle markers?
B.
bitbrusher
Re: How to create my own markers?
Postby Tonio » 01 May 2017, 06:30
Hi Bitbrusher
It'squite simple.
You can import wpt created with Googleearth (kml format) or create them directly (long press on the moving map)
Once the point is created, you can edit it in the "Nav Item" windows
Their you can choose:
Item type: Maker Beacon MB
Type: Inner - Middle - Outer
I hope it's answering your question
PS1: Make sure storing them in a file folder located outside/ beside the "World database" folder
PS2: if this are beacon missing in the nav database that should be added, do not hesitate sharing them
