Finland P and R areas
Postby japax » 15 Jan 2015, 20:28
Could it be possible that the R111A, R111B, R99A and R99B
(western Finland, north from EFKK) are missing from the
database? I have not found a way to get them visible.
japax
Re: Finland P and R areas
Postby kitercuda » 16 Jan 2015, 14:55
Thanks, version 16.66 will solve it. You will need to import the World nav databade again.
Postby japax » 16 Jan 2015, 15:52
Sounds like a plan, thanks in advance.
I would also like to hide all TSA and TRA areas since they are
quite useless here for a VFR pilot. Now, if I want to get info of
some TMA or CTA by tapping the area, it shows the info of the
TRA of the same area. Naturally all D, P and R areas should be
visible, preferably separately colorable. Too much to wish... :?:
japax
Postby kitercuda » 16 Jan 2015, 16:12
Now, it is impossible to select which special use of airspaces to hide (all hide or all show).
I can implement it (llike controled airspace filter.
Question:
A02, B02 etc. are they TSA airspaces?
B01, C01 etc. are they TRA airspaces?
Have a look Menu/Tools and info/Airspaces and patterns
Postby japax » 16 Jan 2015, 18:04
Thanks for the hint! I had forgotten that I can delete some objects :oops:
I removed TSA and TRA areas, changed most of D areas to "Not specified"
set some light color for them to be not so visible and red for P and R areas.
My issue is therefore solved. Until the next database update, after which I
have to do the same again, I think...
If I remember right, TRA and TSA areas exist only in controlled air space
so maybe the controlled air space filter would hide also TMA's etc...
I guess you already know this document but here is the list of TEMPORARY
RESERVED AIRSPACE (TRA, LOCAL TRA), TEMPORARY SEGREGATED AREAS
(TSA) AND CROSS BORDER AREAS (CBA) in Finland:
https://ais.fi/ais/eaip/pdf/enr/EF_ENR_5_2_EN.pdf
japax
Users browsing this forum: No registered users and 33 guests
