Italian small airfields, UL and GA
Postby Werner » 08 Mar 2013, 09:47
its possible to add all italian UL airfields (campi di volo) and GA and UL airbases (aviosuperfici) ?
http://www.ulm.it/hangar/mix/mnulm/arfh ... l/waip.htm
Can you please public the instructions to edit the file gpsilsvor.db
b.r. Werner
Werner
Re: Italian small airfields, UL and GA
Postby kitercuda » 08 Mar 2013, 11:22
Edditing gpsilvor.db - impossible for user. Only me can do it :-)
Just joking - is very difficult to do it, beecause there are several tables which are connected by dynamic created keys, so editting is possible only via FLY is FUN...
But you have a lot of possibilities for importing external files (try user guide version 10.4, there is support fot GPX, KLM and text file). I tried to import campiArf+aerop130131c.gpx, and it works... Copy file to Android device, run FLY is FUN, open nav item list, create new folder, open this folder, press Menu / Import and find the file.
Look here viewtopic.php?f=6&t=5395 (it is from user guide)
I prepared italian airport text file (using Word and Excel). Try to import it (unzip first).
Italy_UL_APT.zip
(5.78 KiB) Downloaded 547 times
Postby Werner » 11 Mar 2013, 17:52
In the version 10.5 is possible to nominate each imported waypoint, or waypiont group, as APT, WPT, VOR or other.. 8-)
Werner
