Russia controlled airspaces and restriction zones
Posted:
09 Feb 2013, 20:33
1. Download files
2. Unzip files
3. Copy files to your device
4. Launch FLY is FUN
5. Menu/Tools and info/Airspaces
6. Delete all Russia areas (long tap at UE, UH, UI, UL, UR, US, UU, UN, UW and press delete)
7. Menu / Import
8. Find and tap at RussiaControlledAirspaces.gia
9. Menu / Import
10. Find and tap at RussiaRestrictions.gia
Many thanks to Sergej for his help
Re: Russia controlled airspaces and restriction zones
Posted:
11 Sep 2013, 15:53
does anybody have current Russia airspaces? If yes, I can make import them to FLY is FUN database...
I need this:
- Name, Code
- coordinates
- low altitude, high altitude
- class
- in case of CTR or TMA ICAO code
Posted:
11 Sep 2013, 19:18
by Stranger
kitercuda wrote:Hi,
I need this:
- Name, Code
- coordinates
- class
Click Download link on
that page. Will that do?
BTW, it's said there that Russian authorities are going to change it a lot very soon. Again.
Posted:
11 Sep 2013, 20:00
Thanks a lot, I will have a look...
Edit: I had a look, tried import - but CTRs are missing (I have checked Moscow)
Posted:
16 Sep 2013, 18:56
by Stranger
kitercuda wrote:Thanks a lot, I will have a look...
Rather strange. It is there in the file, although under its Russian name written in Latin script. I guess such spelling might be a problem for non-Russian users.
- Code: Select all
AC C
AN Moskva
AL 450m MSL
AH FL40
DP 56:34:59 N 37:17:59 E
DP 56:02:59 N 36:23:00 E
DP 55:56:00 N 36:29:00 E
DP 55:38:00 N 36:02:59 E
DP 55:01:59 N 36:24:00 E
DP 55:01:59 N 37:32:59 E
DP 54:59:00 N 37:46:59 E
DP 54:58:00 N 38:12:00 E
DP 54:45:59 N 38:53:00 E
DP 55:19:59 N 39:00:00 E
DP 55:29:24 N 38:54:00 E
DP 55:55:00 N 38:54:00 E
DP 56:00:53 N 38:16:18 E
DP 56:21:59 N 38:17:59 E
Posted:
16 Sep 2013, 19:46
by Stranger
And yes, there is this .kmz file to be used in Google Earth with Russian airspace information updated online.
Looks cool. I can export all the current relevant info into a .kml, but then again, all the textual info is in Russian, and there's lots of it, so it has to be purged somehow. I have attached a file with all the CTRs/CTAs as an example.
- CTRCTA.zip
- Example file with current Russian CTRs/CTAs from Google Earth
- (473.51 KiB) Downloaded 817 times
