Prohibited and restricted area not existing LFP86 & LFR86
Postby dcoquelet » 20 Apr 2020, 20:34
FiF Is showing in the vicinity of La Hague, two area prohibited LFP86 and restricted LFR86 not existing in the French AIP nor on the OACI French chart. Only the LFP7 is currently existing..
Where does these areas come from..??
See Screen shot attached
Best regards
Didier
Capture OACI2020.JPG (118.51 KiB) Viewed 4995 times
Capture LFR86.jpg (316.7 KiB) Viewed 4995 times
Capture LFP86.jpg (303.41 KiB) Viewed 4995 times
dcoquelet
Re: Prohibited and restricted area not existing LFP86 & LFR8
Postby dcoquelet » 20 Apr 2020, 20:36
To continue with attached document from French AIP (LFP & LFR)
dcoquelet
Postby dcoquelet » 20 Apr 2020, 20:44
Another issue is LFP7 for La Hague prohibited area is showing two circle at the same time where there is only one area as per the French OACI chart
Capture LFP7.jpg (253.57 KiB) Viewed 4994 times
dcoquelet
Postby dcoquelet » 22 Apr 2020, 09:37
In fact they are filed in a specific chapter ENR 5.1-5-1 ZONES PROVISOIREMENT INACTIVES TEMPORARILY INACTIVE Areas.
As not shown on OACI country official chart they shouldn't be shown I believe.. This in order to have clear situation on real prohibited, dangerous, or restricted areas
ENR 5.1.5.1 - ZONES LF-P 86 - R 86.pdf
(41.99 KiB) Downloaded 443 times
dcoquelet
Postby kitercuda » 23 Apr 2020, 18:35
Hello
Thanks for this information. I will try to solve it.
