pattern for france?
pattern for france?
Postby rotaxquax » 08 Apr 2019, 20:27
Hi guys,
switched my Fif to france map and
I don't see any holding pattern for france strips and cannot find any "switch"
My German ofm works perfect with all very good features.
Thanks for any idea.
cheers harry
rotaxquax
Re: pattern for france?
Postby Tonio » 16 Apr 2019, 03:44
Hi Rotaxquax
Could you explain what you mean, as I don't understand
May be it will be easier in French (for me)
Postby rotaxquax » 16 Apr 2019, 09:01
Hello tonio,
Sorry for my bad English.
I meant with holding pattern --> traffic circuit.
So in German maps ( for instance OFM maps)
there are a lot of traffic pattern for almost any
air field.
My question is:
Are there this traffic circuit drawings
for France as well?
If yes, how to " Switch on" in the Fif software.
Best regards
harry
rotaxquax
Postby Tonio » 19 Apr 2019, 14:26
Hello Rotaxquak
Airports Pattern/Circuits (as ULM RWY and minor airfield RWY) are created users.
To share them can with the community, they can then send to Petr Kouril, which integrate them.
This what I did some years ago for some french ULM airfields
Airports Pattern/Circuits, RWY, airspaces are created using Google Earth then imported within FIF
For airports Pattern/Circuits, the creation procedure is described in chapter 22.1 of the user guide.
For RWY, the creation procedure is described in chapter 11.3
Almost “rectangular” Airports Pattern/Circuits, are easy to create
ex Left hand for RWY 11 AND right hand for RWY 29
But I didn’t find how to draw them and make them nice when all circuits are left hand (or all right hand)
ex Left hand for RWY 11 AND left hand for RWY 29
Try you will see, how easy it is
Enclose some example to use within Google Earth for PC https://www.google.com/intl/fr_ALL/eart ... wnload-pro
Have fun
Tour de piste - Circuit Pattern.kmz.zip
To use with Google Earth
(3.83 KiB) Downloaded 449 times
Postby rotaxquax » 21 Apr 2019, 18:40
Hi Tonio,
Thank you for your instructions.
But I guess there is a small misunderstanding.
For instance
The airfield LF7753 Bray sur Seine...
there are infos about ULM, landing directions (06 ...24)
and so on, but I cannot see any rectangular traffic pattern.
Is this the fact or do I do something wrong with
some Fif adjustments?
By the way
Happy eastern all
regards
harry
rotaxquax
Postby Tonio » 23 Apr 2019, 01:05
Hi Harry
For LF7753, you see the RWY, that were manually designed using Google Earth
ex attached
LF7753.kmz.zip
(1.37 KiB) Downloaded 439 times
then incorporated by Petr Kouril within FIF database
But you are right, there is no (rectangular) traffic pattern, as nobody did design them yet
or, if someone designed them, they are not yet incorporated within FIF database
Feel free designing them and sharing them with the community
Have nice and safe flights
