Pdf problem
Pdf problem
Postby Pumapilote » 22 May 2016, 15:17
I can't attached pdf to a waypoint created by myself
Pumapilote
Re: Pdf problem
Postby Viking » 22 May 2016, 17:35
Edit your waypoint and write a short name in "ICAO code:", exemple: ABCDE
after, on map, you click on your waypoint and then click on "PDF".
FIF will open pdf (if exits) or create in GPS_ILS_VOR/PDF/ 2 folders: AB folder and inside, ABCDE folder.
Inside this last folder, put your pdf.
Viking
Re: Pdf problem
Postby Tonio » 22 May 2016, 22:32
Viking wrote:Hi
Super :D
Re: Pdf problem
Postby Pumapilote » 25 May 2016, 10:54
Thanks you but it didn't work
Pumapilote
Re: Pdf problem
Postby kitercuda » 27 May 2016, 07:34
For example:
GPS_ILS_VOR/pdf/LK/LKPR/LKPR ADC.pdf
Re: Pdf problem
Postby Pumapilote » 03 Jan 2017, 16:57
Pumapilote
