FSX2ANDROID
Microsoft Flight Simulator X to Android
FSX2ANDROID
Postby nando21 » 18 Mar 2017, 07:56
Hello, I bought FSX to android a few minutes ago, but I can use it yet. I have some problems, I really dont know what happen.
my pc is windows7, it has .net framework 4.6.1 , FSX SP2.
In my mobile SAMSUNG GALAXY S6 is installled the version client.
I dont know what means Any application using GPS. Must I download any from PLAYSTORE?
my PC and Android device are in the same network.
ok, I open the server FSX2ANDROID.EXE.
the ip address is right to both PC and android device.
I activated the mock location app for FSX2ANDROID in my cellphone.
finally I press connect without connnection, I cant see GPS.
How can I solve the problem and use the application.
I send to you some pictures.
regards
nando21
Re: FSX2ANDROID
Postby iverg » 10 Sep 2017, 20:57
Hello Nando
It looks you have the same my problem.
Looking at your pictures FSX2Android is working (communicating) correctly with the PC. Your navigation app is not updating the position because when you switch to the navigation app you put FSX2Android in background and it stops the communications.
I have a Samsung S7 which is able to show on the screen two apps together: I put both the FSX2Android and Navigation app together in order to be both active at the same time and everything is working!!!
I hope the developer can fix the issue and let FSX2Android communicate also when in background.
Ciao
Iverg
iverg
Re: FSX2ANDROID
Postby kitercuda » 22 Oct 2017, 13:07
Hi, did you alllowed mock position in Android settings?
Re: FSX2ANDROID
Postby Viseng » 02 Apr 2018, 13:13
I Have the same issue on Samsung tablet. the android app receives data from the server ONLY when the app is running either in the foreground or side by side with SkyDemon. the app needs to be modified to continue to run when in the background in the same way that the GPS sub-system runs as a service.
Rob
Viseng
Re: FSX2ANDROID
Postby Vitaliy » 13 Feb 2019, 22:21
I have same problem like at the pictures. How does it fix?
Vitaliy
Return to FSX to Android
